stuck spark plug
Bingo Jed
Car: 99 Frontier XE, 99 Altima, 96 Prelude SI, 96 Geo Tracker, 95 240sx SE, 88 Suzuki Samurai, and a push lawn mower.
Just brought home a 99 altima parts car and figured I'd run a compression test before pulling the engine. I warmed up the engine, unplugged the disty stuff and pulled the fuse for the fuel pump, and then went for the plugs. I noticed that the plugs for cylinders 1, 2, and 3 were torqued down pretty tight, which I thought was kind of strange. My big problem now though is I can't seem to get the socket on the plug for the 4th cylinder. It's difficult to get a good view of things since the plug is so far down into the head. At first I thought the nut section of the plug was somehow stripped off. I put a plug back in cylinder #3 and inserted the socket and extension onto it and measured the depth. I then did the same thing for the 4th cylinder and it doesn't seem to go down as far, meaning the socket isn't going over the nut section. I'm using a 5/8" socket plug, which worked for the others. A 7/8" socket won't fit into the opening.
Anybody have any idea's on how to get this plug out? I'm anticipating this to be a difficult one to budge, so I've already sprayed it with pb blaster. When looking into the opening, I can't make out any area's that look like something a socket would go over. The rest of the top part of the plug is there though and the engine starts and runs ok.
idk. Help!?
Bingo Jed
Crisis averted. apparently whoever put these spark plugs in lost their rubber bushing piece from their socket.
And I just did a compression a test and got 180, 182, 178, and 175. :)
Not too bad considering this thing has 162k on it!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
That was going to be my answer..did someone leave a rubber in the tube?
