Stuck Rotor
vto
Car: 1992 Nissan 240sx coupe
Ok everyone, I looked and serached, maybe not as well as I should have but I tried. I bought a set of new drilled rotors, I put them on and surprise, after putting the caliper on, they won't turn. Yes, stuck, I need help with this. They are 20mm rotors from what I saw on them, non abs. Is there a diffrent caliper I can use from a diffrent car, anything, i'm stuck with these till I can figure something out, any help will be greatly appreciated and any negetive comments will fall in def ears, sorry but i've gotten a few before, but I have questions and figured I would ask. Anyways thanks for any help everyone.
Modified by vto at 8:43 PM 4/1/2010
simmode1
Car: Red '95 S14
Is the caliper seized?
When I had this issue before, it was actually due to the little shims that hold the brake pads in place. I had to trim them a bit to let the rotor spin freely...
vto
I removed the shims and still got nothing, the calipers are not sized thou. They are stock calipers that came with the car, I don't know if diffrent modles came with diffrent sizes like maybe the s14 came with bigger calipers or something
