AntonioG »
https://forums.nicoclub.com/antoniog-u200302.html
Thu Aug 30, 2012 6:07 pm
For the belt on the power steering pump, you have to loosen up the hinge bolt it's on. Then, there's the bolt that keeps the adjuster from moving. You'll see it on the bottom left of the PS pump. It'll be in a slotted bracket. The long bolt just behind the bracket will actually relieve the tension on the belt.
The one for the alternator is pretty much the same, just mirrored onto the right side of the motor.
The AC belt tensioner is easiest to get to from under the car. It's just a pulley that sticks straight down. Loosen the center bolt, then use the bolt on the end to adjust the tension on the belt.
And yeah, I'd see if you can pull it up just a bit more. For mine, I kind of had to "roll" it into place. By "roll" I mean rotate it(with the chain on it of course) clockwise while pulling up. Trying to use the chain to push that tensioner back a bit.
