jjbuzzman »
https://forums.nicoclub.com/jjbuzzman-u61200.html
Fri Jan 18, 2008 10:47 am
My '90 Q has the classic worn out key cylinder syndrome - the key goes halfway in and you have to work with it awhile to get all the way in. A search in the forum reveals several solutions that have worked for others - I 've done the graphite with little improvement.
Thus, I am left with (1) get a locksmith to rebuild the cylinder (2) order a factory key and see if it helps, or (3) get a key copy and see if it works any better. One additional option that makes sense to me would be to get a used, low-mileage replacement cylinder with keys and replace the whole thing. This would leave me with two keys to use - one to start the car and one to lock the doors. But then, were I to exchange both front door locks from the same donor, might I have a solution that would work with one key?
If anybody has done this, comments on technical challenge? Any problems with the security systems of the car when swapping out ignition and front door lock cylinders?
Thanks, Jim in North Carolina ('90, '91 and '93)
