Steve Sauer »
https://forums.nicoclub.com/steve-sauer-u8409.html
Wed Jul 02, 2003 5:49 am
I really need to get into this more. It would help if I were more mechanically minded, which I'm not. The shift lock release will not work if the relay goes out because it derives its power from the relay (my understanding). That is intentional because they don't want you driving without brake lights which is what happens with the relay out. I call it a relay because that was what I was told; it may really be more appropriately called a switch. The mechanic who found the problem before found it quickly as a result of having a schematic available. How he got that so quickly I'll never know... If I press on the brake I can hear the relay kick in and out, but the brake lights come on only intermittently, and they will not come on with the brakes fully depressed. Nor will the unit shift out of park while pumping the brakes to energize the relay. This time around is a little different from before in that this time I can get the car out of park with the ignition off and then start it in neutral and at least drive it (without brake lights). The last time this happened it would not go out of park period.
