Stuck in Park
Barryman
Car: can't afford any
Okay folks, I am working on a buddy's '91 Maxima. The shift lock does not disengage when he mashes the brake. The linkages are all good and the switch works. I checked the voltage at the power for the accuator and I am getting 6mV. Is this right? I tried the fire the thing with a 9V battery which actually read just over seven volts. At the switch a I am reading 12 volt plus or minus. It seems the voltage drop is pretty severe from 12V to 6mV but I don't know if there is a digital controller running it or not. That would account for a smaller voltage but 6mV seems almost like background noise. When I press on the brake the voltage at the accuator power does not change - though I would expect it to. Does this accuator go bad? Any help would greatly appreciated thanks.BarrymanBTW the manual push button does work so he's not really stuck!
s13sr20chris
yeah, accuators are a common prob. never heard of one going all the way down to 6mv. thats a purely analog circuit. 12v and ground are your only choices.
Barryman
Okay folks for those of you who will run into this problem in the future... On the advice of one of our moderators - NCRxxx or something like that, I traced the problem to my brake lights. In the brake light assembly the stop lights are two filament bulbs. I had one pad in the socket that was not making contact. The bulb was not lighting is how I found which one didn't work. Well I wiggled it in and out a couple of times and it came on and the shift lock released. Then about a week later the same thing happened. When I took the socket apart I noticed the "connector buttons" in the socket were not the same height. That is the deal. It was also a little coroded, water got to it somehow. Now I just have to figure out how to level these contacts. Maybe I'll file down the higher one as the bulbs have their own "buttons" that could still reach the shorter versions in the socket.
s13sr20chris
oops yeah, forgot to mention that those 1156/1157 bulbs melt and stuff.
AnglerfisH
you're telling me! The taillight harnesses on my '89 GXE had wires melting in them!! :eek: Had to have them replaced. thank goodness they didnt catch fire ::whew::
s13sr20chris
yeah, they are so cheap for a reason! they do that a lot.
AnglerfisH
it took 15 years before mine did that (last month).
s13sr20chris
does your bio actually say you have an a31 maxima?
NISTECH
wouldnt that be a J30 max?
AnglerfisH
oops...lol ::corrected:: my bad, on a different planet when i registered.
s13sr20chris
yeah, a31 is no max for sure. its the jdm cefiro. rwd, rb20det, and q45 looks. just a little smaller than the q though.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
its funny how the max has J30 for its chassis code, but its nothing like an infiniti J30...
s13sr20chris
yeah, i dont know why they did that. the j30 max seems more like the u11 than anything else.
