Stuck in Park????
Car: 1993 Nissan 240SX SE Limited Editon convertible
1993 Nissan 240SX convertible stuck in "PARK" car wil start no problem, but can't move shifter out of park......also noticed brake lights won't come on when stepping on the brake. Can anyone help me, please & thank you.
DAEDALUS
Car: 1990 Infiniti Q45
Sounds like a bad brake switch. Not sure where it's at, but probably a mechanical switch near the pedal.
PalmerWMD
Car: 2004 350Z
exactly what robert said..
In Nissans brake lights and shift lock are on same curcuit.
Check all fuses carefully, if one is burnt you might be bale to fix.
If it keeps buring out trace the circuit and fix problem.
In the meantime you should have a mechanical shift-ock release switch in my car its on the console on floor that houses the "shifter" a button you can push.
Am not sure 240 has that but should..
Even If no fuses burnt your problem is still on that circuit just wont burn thru fuse is still same circuit.
Fred..
s13sr20chris
got all that buddy? they are right on the money. if you cant find a shift lock release try popping the shifter panel up and looking under it.
You guys are awesome, I will check out all those points and let you know how it goes. Thank you ever so much!!!!!!!!!!!!!!!!!
