stuck in gear please help
al240sx
thanks a million i did not know u can pull out codes from the tcm i though only from the ecm.now do you have any idea were to connect the snap on machine to get the code from the tcm and do they rent them or only taking it to a shop with a snap on tool will do it.thanks alot ill try to see if i can find the connecter to get the codes from the tcm.
:D
NISTECH
it is the same connector you get the codes from the ecm. Gray connector near your fuse box.
al240sx
hey is my car obd2 or obd cuss it thought it was obd2 theres a connecter on the passenger side under the clove compartment next to the consol and that is were i connected the obd2 connecter.and came up with code p1605.but then again when i was looking for the a/t control unit i recall seeing a connecter(dont remeber if it was gray or not) but there was a connecter and looked like u can plug in something to it?It looked smaller then the one from the passenger side.can it be that this car has both obd2 and obd if not i do remeber seeing a coonnecter around the fuse box.
o by the way my brother things that the codes he got from pep boys when they puyt it was the oxygen sensor and a oxygen vale?can that cause it to go in safe mode and stay in one gear all the time?
thanks alot u really helping me out with this drama i love the way the car runns great just dont kick no gears.
ps are your from california?
Alex
NISTECH
your car has OBDII but the connector I am reffering to is the consult plug. I am not sure if nissan has a trans data wire in the OBDII connector that year but I do know its in the consult plug. The snap-on scanner will have adapters for pluging into both connectors to pull codes.
No the O2 will not cause the car to go into trans fail safe.
Yes I am in the sacramento area of california
droll
Since your car is 95 I would think OBDI. OBDII is 96 and newer.
NISTECH
you are correct droll the law says 96 and newer have to be OBDII but on all the nissan models the had a model change in 95 got OBDII so they could see if it would operate as the government required.
al240sx
what kind brand model type of scanner can i use to get the code from the dlc thats located in the fuse box?Or at this point do i have to take it o a shop?is that connetor consider obd1?
sorry for all these question just trying to understand and make sure i got it
NISTECH
you will have to take it to a shop to retrieve the codes unless you can find someone that loans a snap on scanner. There is no such thing as an OBDI connector. that connector is for the consult[nissan factory scan tool]
Are you in the sacramento area?
al240sx
fine fine fine ill take it to the freaking dealer i checked the price 80 dollars to scan it:mad: but i have to do what i got to do.
im in los angeles south west los angeles close to culver city:pface
al240sx
i forgot to mention that my o/d light does not come on at all if it means anything?
al240sx
I cant believe i was 5tupid enough not to check.All it was that for some reason the 7.0 fuse were the a/t cont fuse connects was missing.Someone must of taking it out removed it im thinking it might of been pepboys.But i dont think it would just fall off.But anyways thank u allllllllllllllllllllllllllllllllll for the replys and taking some of your time to help me out.Really appreciated.
:ylsuper :)
