stuck hub
Beems240sx
Car: built S14, E30, R6 raven
im swapping out the rear hub in my s14. everything is all unbolted and a tried a lot of pb blaster and a 5lb sledge but it doesnt want to seem to budge. any tips or tricks? its late and i didnt want to wake up the neighbors with the hammer noises. im thinking about torching it in the morning
Ilvemynissan
Car: 240sx s13
What won't budge? the hub out of the assembly? All i've ever had to do is put the assembly on blocks, then get a big socket (around 30mm I think) set it on the hub and hit it with a hammer a few times.
Dattebayo
I'll bet you didn't get everything off yet.
Beems240sx
ill try the block method tomorrow that seems like it would work.
im 100% positive everything is off. its just rust holding it to the assembly.
slideways92
Car: 1992 nissan 240sx se super hicas
Did you get it off? I am in the same boat now? I have tried a hammer and a puller on the axle but seeing as the axles are half shafts they just slide back, yet the hub will not budge? I would like to thank the midwest
