stuck drive shaft...
salt!
Car: 93 s13
my mckinney 1 peice is stuck in my rb25 transmission. i went to install it and it went in a little was and stopped. so i tapped it a little with a rubber hammer to try and get it going. Then i thought it would be a good idea to stop and take it out, but it doesn't want to come out of the transmission...
help please...thank you eric
Shocker
Car: 89 240sxHB rb26/30
Make sure you use lube on it next time if you didnt..... pull harder my friend, pull harder.
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
i had the same problem with my mckinney it was tight as crap but it finally went in there just make sure everythings lined up and try it again and like he said pull harder.lol
FAST-DATSUN
Make sure the splines are CLEAN and lubed on the shaft and the yoke....
Joe
also make sure you are pulling/pushing as straight as possible.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Wiggle it evenly in every direction and try to shoot some lube in there. It isnt about force in situations like this because you will just end up jamming it. Like Kamin said make sure the splines are clean. I used a toothbrush to fish out some grime that was in the ds yolk and on the output shaft.
FAST-DATSUN
use a plastic dead blow hammer to get it moving...one it is apart check to make sure splines on the out put shaft straight...
