Sometimes (not all the time) when the engine reaches about 3000rpms or about 50mph, one of the fuel injectors stops working which causes the engine to skip and sputter like it is running out of gas. If you let up on the accelerator, it smooths out. What has been done already:
- Fuel filter replaced
- Fuel Pump replaced
- Mass Air Flow Sensor replaced
- Checked voltage at the malfunctioning fuel injector and when it is acting up the voltage is 0v
- Applied external power directly to the malfunctioning fuel injector and it started working correctly
- Took the vehicle to an auto electrical specialist to look at the wiring. They kept it for a week and charged me $500, then they said that they could not find the problem and if I wanted them to keep looking it would cost $1000-$2000 more, with no guarantees.
I am at my wits end. Any advice would be welcome
Thanks,
Jim
