Stubborn passenger axle - $10 DIY slide hammer
garu35
Car: 2010 Nissan Rogue SL AWD
Thought I'd share this cheap solution to removing a stubborn passenger side front CV axle. (2010 Rogue)
Cost ~$10 for parts:
- 3" exhaust clamp
- 36" 7/16 threaded rod
- nuts & washers
- used old hub as hammer part of slide hammer
Had to apply MAP torch to bracket holding the carrier bearing for about 2 minutes, then the slide hammer worked on a few hits.
Previous attempts, I didn't heat it long enough, and the clamp started to slide off, and had to be reset.
I empathize with anyone having to do this repair.
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
Necessity is the mother of invention. Slick.
garu35
Thanks. I can't take credit for using the exhaust clamp though, that was YouTube.
darylzero
I have that same problem. Used a MAP torch and slide hammer for an hour! Wouldn't budge. Had to bring it to a mechanic who used acetylene to free it. Gotta love rust
Return to “Rogue Forum”
