98birdls1 »
https://forums.nicoclub.com/98birdls1-u33156.html
Wed Jul 05, 2006 6:54 am
On my old LS1 car the pulley was a pain, trick we used was to get a blow torch and heat the pulley up so it'll expand some. Not sure if it worked or not, but it felt like it was eaiser to get off than doing without it.
Keep the torch away from the crank or you'll be making things worse for ya.
If that doesn't work, a 3-jaw puller should eventually work, like was said, its either going to break the pulley completely apart or bend the bolt. While you turn the bolt, try hitting the pulley with a ball-pein hammer. Light sharp whacks (dont break it) should help break things loose a bit.
And PB blaster works freakin wonders. Good luck
Luke
