Here you go:
http://www.harborfreight.com/c...93124
1/2 gun, 625 torque.
An air tank is useless without the following
pressure (125 is the standard). Max torque is @ max pressure, don't try to use the gun when the compressor is on (under HIGH load requirements).air flowa 200' 3/8" air hose will have a pressure drop and a flow restriction. For TOUGH jobs, a 25' standard hose or even a 1/2" hose should be used (vs a 50 or 100')...The right gunDuhh, a crappy 200lb ft gun will do nothing.. A nice powerfull 1/2" gun is usefull in high torque applications. A stupid powerfull 1" gun is more expensive and you'll rarely use it.
Here are the air guns I have:
http://www.harborfreight.com/c...37730h ... 28SLOOOOOW, uses a lot of air, VERY compact though...
And my big gun for stupid bolts:
A 1 gallon air tank @ 125 psi with a short hose and a good gun will remove the front bolt.. You might have to wait 1 ~ 3 times for the compressor to bump up to 125psi again after you've hit the bolt a couple of times..
This compressor will work, again, max torque @ max psi, wait till the compressor turns off if HIGH demands are needed.
http://www.harborfreight.com/c...90539
My 2 cents says buy the BIGGEST and baddest compressor you can afford if you've got a shop.
