Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Mar 17, 2014 3:58 am
That's a new one. Usually the play is due to worn/non-engaged c-clips, but that would produce an in/out play as well, not just an up/down play. I'm assuming the play is in all ranges of motion, ie fore/aft, up/down, all the diagonals in between. One thing you can do is take the cover off and watch the diff when you're check the stub play and see if the unit itself is moving. It could be the pre-load of the shims are REALLY low allowing it to move somewhat, or the bearings could be bad. Hopefully someone else can chime in that might have experienced something like this.
