terrycs wrote:The question is if the CVT can hold the power and if so, for how long. STS can't answer that. Rear mount turbo(s) are cheaper because you get to use the stock exhaust manifold(s). But then the cost maybe offset by the cost of the one-off exhaust system you'll need to fab that makes two trips across the car from the rear mount turbo compressor to the FMIC/motor, then back to the turbo's turbine.
Also the problem of where are you going to run the piping? Def enough room for the turbos in the rear but the charge piping is a different story. It's tight as it is unless it's smaller piping like 2" all the way. Then you have to run cooling lines, oil/water, that wouldn't be too bad. But yeah, I dunno, just doesn't seem like a good idea on the Altima. I'm sure it could be done, but meh.
