Guys guys guys (and girls),
The removal of both these parts, when done right, takes less the 60 seconds each. I kid you not.
Don't keep trying to do it the wrong way, over and over and over. If you're not getting it STOP, and understand the RIGHT WAY to do it (these threads have covered it in very good detail).
To the OP: There may not be a real good way to fix this. You might need to replace the cable. Even if you do "bend it back" chances are its gonna be weakended and become brittle and subject to breaking (sorry, but that's probably the case).
When I did this install it was very easy, AFTER having read through these threads to learn from others experienece first. Listen (read and look) closely to what is being said, then go ahead and do it. But this is one where you gotta follow the advice being given CLOSLEY or things like 3 hour (plus) installs and the picture above are going to occur.
Sorry to the OP for not being much help, but maybe the next one can avoid these problems. Try these tips among them:
1) On the shift cable:Using a medium size screw driver, place the tip immediately next to the post, directily under and next to where the the cable END PIECE attaches to the post, and gently (yet firmly) pry up and toward the intake (best leverage is from the outside going toward the intake). It will pop off easily when you get the right leverage. VERY LITTLE FORCE IS NEEDED. It's all about leverage and the right angle, not brute force.
2) On the retaining clip:Using a large needle nose plier, grasp the tab/top of the clip (lengthwise) and use the plier as a leveraging device to "pry" the clip out of position (rock back and forth as needed). Again, it will come out easily with only moderate force needed.
There's a lotta people killing themselves on this install and it just doesnt have to be that way!!
Everything (and more) that will ever be needed:
http://forums.altimas.org/zero...ifter
Modified by GreyZone at 9:59 AM 1/31/2009
