Struts, shocks and tires
marioc89
Car: 1990 Acura Legend coupe
2000 Infiniti Qx4 3.3L
I'm in desperate need of struts and shocks and soon tires. I was wondering for the rear, there's a rubber bushing that sits within the spring and it came loose. Can I get that from Infiniti when I go to replace the shocks in the back? Also, what are some really quiet tires that I could get and also capable of off road if need be and keep a sophisticated look of a luxury SUV?
marioc89
So no input on this? Anyone?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
The rubber item sounds like the bump stop. New ones should be available from Infiniti and probably some aftermarket sources. I haven't had experiences with many tires, sorry.
marioc89
I really appreciate you responding with that answer. Thank you.
robbykennedy
Car: 2003 Pathfinder SE
2005 Mercedes Benz C-Class
marioc89,
I had a good experience with Yokohama tires. They are quiet and not very expensive, you can probably buy them from America's Tire http://www.americastire.com/dtcs/search ... =16&cs=255
As far as the rear shocks for the truck those are very easy to replace, you should be able to replace them yourself. These are the recommended OEM replacement for you truck and not cost prohibitive http://www.amazon.com/KYB-343379-Excel- ... kyb+343379
As for the front struts you are going to need someone to do it for you.
marioc89
Thanks Robby and town for your help on this.
greengumby
Car: 2002 Pathfinder- "ole Rusty"
2006 Honda Pilot
good question on the matter I was also wondering the same since I already use bilsteins on my Tahoe I was thinking of using them on my pathy...
Rictavius
Car: 2000 Nissan Pathfinder
I put the KYB Excel G struts on my 2000 Pathfinder. They are terrible.extremely stiff for a very harsh ride. I was told that the rattle for lack of a better term in front was probably struts and/or mounts. Replaced struts and mounts and now noise and feel is worse. A little more research seems to indicate that the problem is front sway bar links. None the less I strongly advise against the purchase of these struts!
