Looked into this myself
Need a ball joit separator for the steering and lower control arm
Good vise to hold the assmebly
big wrench to loosen nut that holds the case. Unit is not like other struts but has a cartridge inside that is replaced.
Suggest going t local shop to have the springs removed and installed.
Look at lower control arm, ball joints, strut top bushing and tension rod bushings while you have everything apart. Replace what is needed at thsi time to save disassembly later
Suggest you get manual on ebay, not the CD. A big help
http://cgi.ebay.com/ebaymotors...75640
