Stock propeller shaft in the rogue is more than half the size of the nissan altima ones. With the sping mounted on the shock it sticks up an extra 3-5 inches. but the back is a different story.ImStricken wrote:struts alone dont add ride height. you need spring, etc. dont forget if you add height, you might need to increase the length of propeller shaft. im not sure ours extends past its normal suspension travel
altima's dont have propeller shafts....SlimSlammedRogue wrote:Stock propeller shaft in the rogue is more than half the size of the nissan altima ones. With the sping mounted on the shock it sticks up an extra 3-5 inches. but the back is a different story.
When you get the new shocks buy brand new springs. I installed brand new factory suspension onto a rogue a couple days ago and it sits higher than normal. I guess it has a break in period for it to settle back down to normal
Are you taking about the shinny metal peice of the strut that you can push down to determine if the struts blown or not?ImStricken wrote:altima's dont have propeller shafts....
This is what he's trying to describe.SlimSlammedRogue wrote:Are you taking about the shinny metal peice of the strut that you can push down to determine if the struts blown or not?ImStricken wrote:altima's dont have propeller shafts....
Densetsu wrote:In a simple case (a rear-wheel drive vehicle), the engine generates rotational power, the transmission converts this to an appropriate torque/speed, and the propeller shaft (aka drive shaft) delivers the output of the transmission to the rear axle. It's basically a long rod with one or two U-joints at the ends that runs from the transmission to the drive axle.
A 4WD vehicle would have two propeller shafts, one going to the rear axle and one to the front axle. A transfer case would take care of managing when to engage the second propeller shaft...
