amolao wrote:Got rust?? Good eye, looks like surface rust. If you can clean the original plates, clean them and reinstall. I like the idea of seam welding the plates, make sure to clean all rust and use something like PQR 15 or whatever is called to.....to protect the surfaces. Also check the underside for rust, clean and protect with a good undercoating.
reusing the plates are a negative.. 13 holes + bent up and rusty = no thanks. i was actually just gonna get some new ones from nissan, until i found out they cost about $75 each (with 20% discount off msrp ).
and yessir i got my die grinder/wire wheel/sandblasting stuff, my new paint gun + rust bullet primer, and my 5 cans of 3m rubberized undercoating
