Q45tech wrote:Your missing the point the whole shock tower metal work bends, the upper link rear mount bolts to the shock tower metal work so this is where the stress is.
All I can say is I installed a load cell [strain gauge] between the rod end and the bar ........something is causing a deflection and the load variance >340 pounds.
A couple of things. Are you measuring deflection or just load? Those towers are built out of very beefy metal and are designed to see serious loads. Second, even if the top of the shock tower is deflecting, the upper control arm attachment point (which is what matters on a car with an upper control arm) isn't deflecting as much since it mounts lower in the tower at a point that almost isn't even the "tower" anymore. I'd guesstimate the attachment point is a good 6-6.5" below the top of the tower.
Quote »Why did Nissan waste money on oem front unit on all 97-02Q?........definitly not for looks cause they chose a functonal bar.[/quote]
Probably because the 97-01 cars use struts, and if a STB is useful for anything, it would be on a strut equipped car, since the location of the top of the strut does affect camber. Using that same logic, why didn't they put one on flagship 90-96 cars that they pulled out the stops on in many other respects?
Quote »Actually the bar helps dampen the tire/road vibrations by rigidizing the body! [/quote]
That's possible and probably why the 97-01 Qs have them. I just have a hard time believing they significantly affect dynamic camber. We're both just arm-chair theorizing here, but tire temperatures would tell the real story. If it does reduce deflection enough to affect camber, you'd see it in the tire temperatures. If I had ready access to a skidpad and STB, I'd go test tire temperatures with and without the STB, but unfortunately I don't have either.
