John, I believe I will be able to get to the plugs if I try. But now I learn that I'll be able to drain and fill to get to the desired concentration so I decide to do a multiple d and f without even jacking up the car though it will take a while and lots of distill water.
If I go for the plugs I know there are surprise waiting to happen as always which comes with frustrations. Such as, let's say, coolant all over my face and everywhere, dropping the plugs into a crack, strip a thread, debris fall into the block, leaking coolant, knocking something else loose or burst knuckles sort of things. Really try not to deal with if I don't have to.
Just as simple as change differential oil the other day; raise the car, remove the drain plug, drain gear oil, reinstall drain plug, remove filler plug, refill gear oil.... simple enough? Nooo...
When I am ready to put that pointed bottle to the filler hole and realize there is not enough room to turn the bottle and I squeeze the bottle nothing came out. Actually the problem is I forgot to peal off the paper stopper from the bottle and jump into conclusion. So got me a long tube and stick it into the filler hole through the wheel well to outside and starts to squeeze the oil into the other end of the tube. It went really slow, so I decide to cut open the bottom of the bottle to make it go faster and without squeezing. As it is going well the bottle suddenly slip off the tube so I instinctively turn the bottle up and the oil is spilling from both end; worst of all, I didn't know which way I should turn the bottle at that moment. After I got in control of the bottle and clean up, I got me a funnel and get it going again. Almost done, I heard dripping so I was happy it is over, but when I look, the tube had come out of the hole and spill about a 1/2 qt on the floor. After cleaning up, went to the Autozone and no more Mobil1 synthetic 75W90 on the shelf. So I have to drive another 30 mile to get one. Finally done.
Next day, because the smell of gear oil was everywhere, my wife thought it was gas leak and call the gas company. The guy came out and really found a slow leak on the flexible pipe connecting the stove. So I took off from work to fix the leak. I really don't know if I should be glad for my stumbles.
Hope this is funny to you. Nite.
