monsterx240sx wrote:I installed my strut tower bars today both front and rear. I was wondering if any of you know what is better to tighten the strut tower bar in (pull the towards the middle of the engine compartment) or out (push away from the middle of the engine compartment)???
Either way, you are changing your camber adjustment, and will require a fresh alignment.
Pulling it in will cause negative camber, and pushing it out will cause positive camber.
My understandin of the brace, is to reduce camber movement under stress.
I put mine at a little outward pressure, since the car tends to flex inward in the corners. Then I had the alignment done, to get it in spec.
