Strut Tower Bolts
Fr0zEn
Car: 1989 Nissan 240SX, Interceptor
I have an 89 240 and no bolts have ever been taken off. I managed to strip most of the outside of one bolt, I have a Megan Racing Strut bar that I want to install. Any clues on how to get that last bolt off? Without using cutting tools.
gumby74
Is this front or rear?If it's on the front, you have plenty of space to use an extractor socket.It's basically a socket with teeth on the inside that taper and wind around the length of the socket. As you turn the socket, the teeth start to dig and cut down into the nut thus completely shredding or removing the nut.You will of course need a new nut.
