Strut top/mount question
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
How many of you changed your strut mounts when changing your strut setup (Not talking to coilover guys because I know new mounts came with yours). I've been told that I should change them just because I'm changing my struts. I have 82k miles and no noticeable issues.
TDot
Bump
svard75
Car: 06 M35x
In a previous life I had swapped springs on a FWD macpherson strut setup (This means the upper mounts pivot with the strut). I didn't replace the upper mounts and regretted that move because they began making funny noises shortly after.
They're relatively cheap right? I would say replace them just to be safe and while you're at it replace the top retaining bolt as well. These nuts have nylon locking washer built-in.
Ilya
Definitely replace them while you're in there.
