You can definitly do that. I have a friend mechanic who only used spring compressors during install. He's a bit nuts though. What he would do is put his foot on the top plate and step down hard as he unscrewed the bolt. The strut and spring would go flying back buthe never injured himself lol. Don't recommend that. Usually the piston would have a nut thread at the top and after loosening it use an open wrench on the main bolt with a smaller open wrench on the piston bolt to keep it from turning.TDot wrote:When you take off the main bolt at the top of the strut, I can imagine that bolt is extremely tight, so once you remove that strut and compress the spring, How do you remove that bolt without an impact gun or air tool? How do you leverage it? I was thinking before I even remove the strut I should barely loosen it...juuuust break it, then take it out put the compressor on the spring to remove the strut top. Or is that stupid and will end in a catastrophe?
Really? I read the opposite tein-h-tech-lowering-springs-install-wr ... l#p6356949TDot wrote:...There was one member that said he had these and eibachs and these actually are a bit stiffer which may be a good thing.
m-licious wrote: tein Htechs
pro: haven't completed alignment yet, but the drop is so mild i can't imagine how it wouldn't be within spec. still looks better than stock but doesn't turn heads like the eibach's more slammed appearance.
con: i think it rides stiffer than stock (which is expected) but also stiffer than my eibachs, which i found odd. comparing published rates led me to expect this but didn't think it'd be so obvious on the butt dyno.
He has an M45 weighing in at 3995lbs, so I'm hopeful the 50lbs difference of mine won't make a difference.jhuerto23 wrote:I just installed H techs and I love em. They lowered my m45 nicely, gave me a tad better feel on the road and responsiveness. Best part was it was really a comfortable ride and I dont have to worry too much on the road since I'm not that low. I am very happy that I went with H techs vs S version. Good luck
