p00t »
https://forums.nicoclub.com/p00t-u5026.html
Sat Aug 09, 2003 9:17 pm
yep, that shaft goes down into the shock, and there are a series of rubber seals from the body of the shock up against the shaft. basically the score is letting gas to seep past those seals.
that is why you should use boots with the shock when you install, it prevents rocks and such from scoring up the shaft, which will in turn allow gas to escape. (not saying it wouldve helped you in this situation though)
