screwinitupagain »
https://forums.nicoclub.com/screwinitupagain-u61403.html
Mon Jul 27, 2009 8:59 am
Strut tower mounts, check the tie rods make sure they are still good, are you going with new coils?, if so then do all of the install at once, if you are going with new coils & you choose to go with lifted coils think about manual hubs, also if you are going with new struts you might as well think about new shocks in the rear & if you are think of doing all of that go a head & replacing your bushings in you lower control arms front & rear. This will probably give a good overhaul of you suspension.
Oh & before you ask, go with KYB GR-2 struts up front & a nice pair of Billstien shocks in the rear.
Good?
