strut replacement idea...
jdurrty
Car: j30
My front struts are blown and Im getting tired of the crappy ride, but I dont want to pay a small fortune for new ones from Infiniti so I hit the local junk yard. I got a spare strut and went to town on it and this is what I found...
I want your input on whether it is worth my time to call up monroe and order some inserts that are close enough specs so they work in my j30. Let me know what you think!!!!
Here is the site for the replacement cartridges:
http://www.monroe.com/products/sensatra ... lloverObj=[object+Object]
yodawill2000
Car: 94 Infiniti J30
Ive read they discontinued the J inserts Years ago.
If you find they have one that's compatible you will be a hero !!!
colincliff2
Oh how happy I would be if there was an aftermarket strut for my car! Let us know if they come up w/ anything. I noticed the prices of the OEM struts just went up again on ebay.
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
my friend shot me the idea of seeing if the 300zx z31 na or tt shared the same shock cartrideges. i never looked into it to see. i know at the local pull a part is like $30 for a strut.
alternative that i am working on is 240sx s14 front 5 lug with abs spindles with s13 coilovers and im swapping to the s14 lower control arm ball joints and tie rod endlinks.
1994 infiniti j30 190+
Car: 1994 Infiniti J30
1990 Ford Ranger XLT Sport Limited Edition
hey wat did you do to remove the bolt that holds in the strut cartridge? i just replaced my front right strut cause it died on me and i ended up using a chisal and a hammer lol whatever works.
jdurrty
Car: j30
I put the strut in a vice clamp and loosened the nut with a really big monkey wrench. did you replace the whole strut or just the insert? for fun, I'm experimenting with the spare strut insert and converting it into an air-ride setup. should have some pics up in a few days.
just the insert cause we acciedently broke the speed sensor bolt on the one we took from the junkyard and then i didnt have to move all the bearings over to the new one. i wish i could have a new one but too much for one. i need to replace my tension rod bushings cause mine are shot and they make a loud clunk noise over bumps. but i have to press them out so its going to be a little difficult.
SIDUDE
Car: J30
jdurrty wrote:I put the strut in a vice clamp and loosened the nut with a really big monkey wrench. did you replace the whole strut or just the insert? for fun, I'm experimenting with the spare strut insert and converting it into an air-ride setup. should have some pics up in a few days.
How did you make out, I need to do both the rear and the fronts, any advice would be appreciated.
Tony@CircleInfiniti
Vendor
Whats up guys,
I have NEW OEM Fronts Struts and Rear Shocks available for a very good price:
http://stores.ebay.com/Circle-Infiniti/ ... =793576131
FRONT SET $329.95
REAR SET $349.95
I can combine shipping for all 4. Please PM me with any questions.
Last edited by Tony@CircleInfiniti on Wed Sep 22, 2010 6:51 am, edited 1 time in total.
yodawill2000
The fronts seem to look different than OEM as in no lip at the end of the strut.
And I just got two rears from rockauto for 50ish shipped for a 89 280z.
Bolted right up.
