Strut Replacement How To??
Mischi
Car: 2001 Infiniti QX4
Is there a write up anywhere on this? I'm thinking about doing it myself and the how tos I've seen on this site help a lot. Thanks in advance.
alexf20c
Car: '00 SE 4x4
raise vehicle
remove 2 lower strut mount bolts (on spindle)
remove 3 upper strut mount nuts (inside engine bay)
remove strut
compress strut coil with strut spring compressor tool
remove strut shaft bolt (the one that holds the hat onto the strut)
remove spring
reverse
get alignnment
