strut noise
natsoundup
the driver side strut on the 90q was making a noise... a rattle when you drove or pushed up or down on the fender.
so I pulled the strut assembly....and the rubber under the top metal cap was obliterated...
I called scottsdale today and ordererd two new pieces of rubber....
I think we finally got the right parts.... is there a gasket that needs to be ordered as well?
I hope I am describing the problem adequately....people call these parts different things on the board...
this would be on top of the outside of the shock assemble... i guess the rubber would go on the top of the shock assenbly...and then the cap on top of that.
DAEDALUS
Car: 1990 Infiniti Q45
There is an orange "gasket" between the body and the top mount. I assume it's function is to prevent damage/noise from metal-to-metal contact. Oddly, the gaskets for the front and the rear vary in price by over $15 apiece if I recall right. Same material, slightly different outline/mounting.
