Strut bearing replacement
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
I think I have a strut bearing going out. Does it have a creakynoise? My CV axles are fine as far as I can "see" and they dontclick. Are the strut bearings hard to change out?
maxhopper
Car: 02 Maxima SE 6spd
Yes the bad strut bearing will have a creaky noise. You can have the car in park and turn the steering wheel side to side and it will make noise.
If you can replace struts, you can do the strut bearings. You'll need to jack up the front end, remove the wheels, remove the two lower bolts that hold the strut to the hub, and then remove the three bolts at the top of the strut. The bearing just rides on the top part of the strut.
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
maxhopper97 wrote:The bearing just rides on the top part of the strut.
right up to this point. you'll need to get spring compressors and compress the spring. then you'll need to take off the nut on top of the strut (good luck without an impact) and take apart the strut assembly - you'll see the bearing (made of plastic).
http://www.courtesyparts.com/m....html
Modified by allensteiner at 2:45 PM 4/28/2009
Modified by allensteiner at 3:18 PM 4/28/2009
maxhopper
Yep, you're absolutely correct. My bad.
lightsout
Car: 00 Nismo Maxima SE
if you don't have a spring compressor, compress the suspension with a floor jack on the lower control arm....then slowly let it out after the strut nuts are removed
