Strut Bearing Replacement @ 9000 Mile and @ 9 Months: Too Early
maverick_rogue
Car: Nissan Rogue 2009 FWD
Hello,
My Rogue (SL FWD 2009) was making creaking sound on right turn for a couple of months.
Had the service guys look at it. Initially they lubricated suspension but it did not work.
Today, they had a second look at the issue and found Strut Bearing had clearance issues. Apparently it was loose.They replaced it and now it works just fine. No noise and less vibrations. Though , I wonder isn't it too early to have a strut Bearing replacement. I would expect this to happen when I change the shox and struts at 30K Miles or so? Any thoughts?
Pescakl1
Car: 2008 Nissan Rogue SL FWD
Iridium Graphite
maverick_rogue wrote:Though , I wonder isn't it too early to have a strut Bearing replacement. I would expect this to happen when I change the shox and struts at 30K Miles or so? Any thoughts?
It is probably a problem from the manufacturing plant in Japan.Some other members had problem with their car because they were not well built and the quality check did not detect them.
Return to “Rogue Forum”
