Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sat May 03, 2003 12:51 pm
"it's a simple piece of metal used to stop moving"
sure, and a tire is just a pice of rubber used to take a car down a road....its true fundamentaly, but in actuallity theres a larger difference than you think.
heres a few pointers:-design. a good strut bar will have solid design structure, low bends, proper clearance for turbos, etc, allong with functional joints, and a good way of securing them. Many cheap bars use adjustalbe sleeves, wich are weak...just one example-materials- a good strut bar will be made of aircraft quality alluminum or other high-strength, light material, with enough to provide rigidity, but not much weight. Cheap bars may use heavy steel or other cheap materials.
those are juse 2 points you should think about before buying a cheap strut bar. Whoever told you the difference was the price is an idiot.-chet
