Strut Bars and Money
lain
Car: 2007 Nissan Versa S
I was talking to a friend of mine that knows alot about cars and he told me that any strut bar that I find online whether it cost $20 or $200 it is all the same metal and will work exactly the same. That all I am really paying for is the label. Is this true?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I've read completely opposite responses on this topic. Some members say it's just a bar and others say it's the strength of the bar and the braces/connectors. I used to think that it was just a bar or metal but after doing some research it does come down to the bar strength and braces. Some bars are thicker and some braces/connectors are just more solid with much less flex. So there has to be some difference in performance...right?
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Basically it's the shape of the bar that correlates to it's stiffness. IMO I would opt for a oval or flat type instead of just round.
Most times you are paying for a name but you can get good stuff for cheap. Don't get the ugly cheap Matrix ones or anything like that but SSAutochrome makes good ones for both the S13 and S14.
Modified by ddgsxr504 at 8:49 AM 10/20/2006
positron1
ddgsxr504 wrote:Basically it's the shape of the bar that correlates to it's stiffness. IMO I would opt for a oval or flat type instead of just round.
Paying for a name...YES!!!
180fan
Car: 89 fastback
at the same time though, if you've taken a hack saw to some of these stb's you will see a difference on the inside as well. some are just flat out hollow and some have bars inside that run the length of the stb, I guess kinda like this ( | | ) <--if you can imagine the top and bottom of that sealed up...
ddgsxr504
180fan wrote:at the same time though, if you've taken a hack saw to some of these stb's you will see a difference on the inside as well. some are just flat out hollow and some have bars inside that run the length of the stb, I guess kinda like this ( | | ) <--if you can imagine the top and bottom of that sealed up...
Yeah I have seen that myself, good point I forgot about that.
