Strut and Sway Bars!
All things Altima Coupe.
jusjus
Car: 2.5 Altima Coupe
Hey guys,
I was wondering if either the strut or the sway bars really make any difference in the driving experience. For those of you who have one or the other, mind sharing if you feel anything? Also, which brand strut do you guys prefer; stillen or racingline? I believe only stillen makes sway bars right? thx for any input! ;)
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
When you write "strut," you mean "strut tower brace," right?
rcboy514
Car: 2013 VW Golf TDI 4dr 6-speed
2008 A/C 3.5 CVT (sold)
2004 BMW 545i V8 >:-)
1991 BMW 535i I-6
Short answer....YES!! Worth every penny!
BzOaY
Car: 2008 Altima Coupe
i love my RL front strut bar and rear sway bar, it owns corners
rcboy514
1991 BMW 535i I-6
Also, for the strut tower bar you could go with either stillen or racingline because you shouldn't be able to tell a difference between the two. For the rear sway it's up to you, racingline's bar is adjustable and has 2 settings, the softest setting is said to be 45% stiffer than stillen's non-adjustable bar. Personally I went with racingline on both the STB and rear sway.
As far as handling goes it's night and day literally. My wife has a stock 2.5 coupe and after driving my car hers feels like a boat.You will experience almost no body roll going through corners, and you shouldn't have any issues with understeer. The STB allows you to "dive" through corners, while the rear sway bar keeps the back end planted while you power out of a corner.
hope this helps lol
BzOaY
i second rcboy514 100% it is night and day difference, i am also lowered on eibach springs and that also helps out alot to
johnnir3volution
Car: 09 nissan altima
Racingline strut and sway bar + bc coilovers = WIN
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
Yooo JusJus, enable ur PMs u sent me a PM but i cant answer u cuz u didnt enable them.. but for ur question, i just took the burger off and broke of the side clips that are inline wit the nissan logo and left the top and bottom clips cuz u can center the clibs in the grill of the C-mod.. but b4 i did taht.. in the back of the burger theres a spot were u can pre-drill two holes so u can fit 2 small zip ties and then zip it tight.. its very sturdy if have any problems enable ur pms and hit me up on that...
DReed86
Car: Altima Coupe 2008 SE 3.5 White CVT
Yes they are def worth it!!!!!!! 100%
