Struggling to find easy top feed fuel rail
Rikter
Hi folks,
Did some searching around and didn't find a thread that was started or a FAQ about this.
I'm looking to find a top feed fuel rail for an S14 VVT SR20DET. I will be using Venom 740cc high impedence injectors, top feed. The only two rails I've found so far are the Greddy (which requires me to use their manifold) and the HKS which requires adapters, lines, etc.
Does a quality company make a plug n play top feed fuel rail? or is my best chioce the HKS?-Rik
Hijacker
Car: '92 240sx Convertible
'94 F-150
JGY Customs has a top feed rail. It should come with everything you need. Clips to hold the injectors, a fitting on the rear for the feed line, and it will allow you to bolt an OE FPR to the front
Rikter
Thanks for the help. Item looks great! One is ordered and on the way soon.-Rik
