Z axles are too long, i do believe. One option is to upgrade to J30 axles. They're the same length, a bit beefier, but they have the JDM style 5 bolt pattern.spider_slayer wrote:i believe that the axles in the z32 are a bit larger then our stockers.
If you already snapped an axle and you are aiming for those times, I'm guessing you're using slicks at the track?Dugi wrote:Anyone know where I can order stronger drive axles?? I just snapped mine at the track. cause if i'm running 12's now and I want to go 11's I really need stronger axles. or is there any other alternative?? want to keep my car street
Yeah I was thinking about that, but my problem is I live on a small island in the carribean. there are like 3 z32 on the island i think and none has crashed yet for me to buy their subframe and to get one from anywhere else is gonna break my wallet with shipping.Dori Dori wrote:
Anyway, what I'm getting at is your diff isn't gonna like launches like that either (nor will your tanny, but that's another discussion). Instead of getting bent over on axle costs and then having to worry about your diff, do a little fab work (not really even fab work) and swap in a Z32 TT subframe. You'll be able to fit wider tires, have a much stronger diff, better brakes, and have much stronger axles (that you could replace cheaply, and easlily).
To answer your question, I don't think any other stock made axles that are bigger and will fit in the stock pieces.Even if you change hub and spindle the ones that match the hub are still too long. You may want to try it with the stock axles agin and setup the suspension where you get a little more tire spin or add air to the tries for the same result. On 360whp we ran 11.72 at 119with no two step and slicks and at 380whp with et streets and a 2 step we ran 11.22 at 131. It can be done on stock axles you just have to have the suspension and tire pressure set right.Dugi wrote:Anyone know where I can order stronger drive axles?? I just snapped mine at the track. cause if i'm running 12's now and I want to go 11's I really need stronger axles. or is there any other alternative?? want to keep my car street
