95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sun Mar 08, 2009 12:49 am
make sure the smell is not coming from the engine bay, it could cause a really big problem if it is, turning on the climate control is not enough proof...... i've seen some shots of engine bays from 300zx on fire because of a fuel leak..... please dont take this lightly
with the engine cold, start it and look in the engine bay, make sure that no hoses are leaking there
is there a big temperature difference between summer and winter where you live ??, if so, then the problem is most likely in the engine bay (one of the fuel rail hoses is most likely loose)
