I wouldn't replace it just because of bad smell inside... The owner that had to change his battery also had other issues with battery not just smell inside cabin... Just a heads up!M35SFIREMEDIC wrote:Check. I thought I read that on eariler post. The cables are clean and I'm not getting any delays in starting. I'll get it tested and swap if needed. Tks!!
Do this! Mine stank and I replaced it at 98,000miles. I smelled it primarily with AC. Let's just say it was Nissan OEM original to the car and overdue. It's 20 mins of labor and under $20 for the cost of the filter.jbracy7 wrote:Replace in cabin air filter
