bmarley5780 wrote:Yes, that is the page I am going off of. Wanting to build the 2.3. It does not say anything about oversized piston. Is this something that is needed but not mention in that write up?
To get up to 2.3 liters, my guess is a 82 mm piston. 4mm overbore. Seems like you would sonic test the block walls, as that is a pretty good size overbore!
Quick math:
disp = 6 * PI * (bore)^2/4 * stroke
with the 82mm bore and 71.7 stroke (RB25 crank)...just about 2.270 liters.
To "clearance" and crank... you take the block, installed the new crank and rods. As they spin you'll discover the hit the walls of the block. Yep, you strart grinding away until you have a good 0.050" clearance between anything rotating and the block.
Given the price difference between a RB20DET and RB25DET... you are ahead of the game by starting with a RB25 engine....
Tom
