redtop91 wrote:Stability of the rotating assembly is lost with strokers, personally, I'd bore slightly and run a fully forged internal setup on a balanced and micropolished crankshaft. Cheaper and easily strong enough for your goals.
Whoever told you this is an idiot. The quality of any rebuild stroked/bored or both is almost entirely dependent on the machinist that performs the work. With properly sized bearings, properly gapped rings, true sleeves (straight), and right hone/gap on piston to sleeves you will have no stability or abnormal vibration. GM push-rod guys have been turning 350 ci (5.7L) engines into 427 (7.0L) for almost 40 years if it was a bad idea do you really think they would continue to do so after 40 years?
One thing that we don't have but would be a good idea is a Harmonic Balancer. The reason our SR20 does not have a harmonic balancer is due to the fact that we have an inline motor (no crank angle intersect) and a square bore (bore diameter is the same as the stroke). When you bore OR stroke the motor you change this (unless you get teh magic 2.35L bore/stroke combo) and need to get an ATI Super Dampener if you expect the motor to last under street conditions.
