Stroke length
Ajax87
plan to rebuild a redtop next year so I'm going over the options. I saw a piston and crank kit from tomei that was only for use with increased stroke. I'm 99 percent sure I don't wanna go this route but it got me pondering the benefits of increased stroke with forced induction?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
yep 90 mm stroke crank i believe. if you build it right you can still hit 8000 redline easy. with a big bore and stroke imagine having an extra cylinder.... almost. more displacement quiker spool, more spool, more torque more power. food for thought bigger stroke, more heat more friction.
Ajax87
Wouldn't increased stroke lower rpms causing more turbo lag
Sugar
Car: S13 w/ Sr
It's still a larger volume of air. I don't know to much about stroker kits, generally people don't recommend them.
Hijacker
Car: '92 240sx Convertible
'94 F-150
On a forced induction setup, people rarely suggest them because they're expensive, and the amount of power:dollar ratio isn't high enough. On a naturally aspirated setup, boring and stroking is one of the top ways to increase power production.
And as for the redline, SRs are notorious for having head issues in the top end, so the stroke kit is negligible in the redline. If I stroked a stock motor, I would still expect a redline near 7000 only because the head is the limitation.
