p1rat3 »
https://forums.nicoclub.com/p1rat3-u57077.html
Sat Feb 17, 2007 5:53 pm
You will need to use bondo even after you use the stud gun hammer thingy but they do i good job to get most of it.
You also dont need to strip the whole car to bear metal, you just have to make sure there is no shine left on it and only take the car down to bear metal where there is like a scratch or dent and apply the bondo
Your better off sanding it than using chemicals too, use a DA sander and some 220 to remove the shine then you can go over it all quick with like 600 or w/e. Use a flat hand block with 80 on it to sand bondo at first so it doesnt take you forever to get it smooth, unless your good at applying it
