stripped threads on block
treesquad
i stripped the threads on the block for the oil feed line, the one closer to the oil pan. The motor is is still in the car. Should i use a helicoil to repair it? Also if i take out he turbo manifold with the turbo what lines have to come off and what percautions should i take
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Welcome to nico! We have a very good forum search button at the top of the forum page's. This will help keep threads that have been covered to a minimum. here's a link: zerothread?id=261748
Remember the BIG RED SEARCH BUTTON! Remember the BIG RED SEARCH BUTTON! Remember the BIG RED SEARCH BUTTON!zerosearch What sr20det motor do you have?
treesquad
i got the helicoil in, but know my promblem is how the f@ck do remove the tab sinnce its inside the banjo bolt hole
supreamS14
I cut the end most of the way before I installed it.
zeause
I had to do the same thing. I lost my washer/brass gasket thing and i didn't realize it so i just kept tightening it and it held til the next time i had to take it off and i had to use a helicoil. I just left the tab on mine and it ran fine.
