Stripped threads in crank for flywheel bolts. Question about Helicoil
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
Well like the topic says the threads on my crank where the flywheel bolts in go to are stripped. I came across Tyrannix's old thread about the same issue he had. zerothread?id=197138 So I know I have a couple of choices of a fix. After checking out the webpages for both Helicoil and Time-sert they only make the correct thread in 15mm lengths. The stock flywheel bolt is 30mm in length from the tip - head, and 20mm of that is threaded. Can I just use 2 helicoil inserts by basically stacking em and breaking off the tangs after installation and cutting off any excess length if there is any. Sorry if this is a dumb question but I have never used helicoils before. And Helicoil and Time-sert has yet to answer my emails about the availablity of different lengths not mentioned on their webpages. Any help or insight is very much appreciated.
Thanks in advance, Wei
themadscientist
every hole is stripped?!
Bwana
Car: Denali
Is the crank flange deeper than 15mm? You for sure don't need more helicoil than you have flange...
Woods Crasher
I had this problem with mine too. Here's what I did
1. Drilled out the broken bolts tap the holes to 7/16 x 20. 2. Drilled out the holes in the flywheel to 7/16 as well. 3. Bought some 7/16 x 20 1 inch long grade 8 bolts from boltdepot.com. 4. Slathered some jb weld on the threads for insurance, torqued them down.
Been good for about 5 months now. Just replaced my tired stock clutch for a spec stage 3 last week and every bolt is perfect. Perhaps I didn't need to jb weld them but I was pissed haha
*edited for clarity*
Modified by Woods Crasher at 5:49 PM 9/5/2007
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
^ sounds like the proper way to go about it to me. Screw that helicoil junk, just drill and tap.
Bwana
Car: Denali
Woods Crasher wrote:I had this problem with mine too. Here's what I did
That should do it. I hope you never have to take it off though...
Loctite FTW.
r34 gtr
Wasnt that impressed with loctite to tell you the truth, my subwoofer managed to rattle some loctited bolts loose, as did my suspension. Tell you what really works though, put a little dab of gorilla glue on there instead. ITS DA ROC!!
Woods Crasher
Loctite FTW.
Nah they came out fine...Just gotta break them loose and they come right out...
anumeric
themadscientist wrote:every hole is stripped?!
from the looks of it at least 3 of them
Bwana wrote:Is the crank flange deeper than 15mm? You for sure don't need more helicoil than you have flange...
Good call Bwana, I finally had the chance to pull the motor out and got a measurement on the depth and it was only 15mm, so I was kinda jumping the gun a bit. I had assumed that it was at least equal to the threaded portion of the bolt.
But thanks for all the responses and suggestions guys!
Wei
