stripped the ring n pinion gears in my r200, WTF??????????
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
i just took apart my rear end that came apart on me on the dyno and come to see metal shavigns every where, the pinion is smoother then a strippers a$$, and the ring gear has more teeth missing then are intact
has this happened to anyone on here before? any input would be helpful!
are there any companys that sell a hardened ring n pinion set for the r200 housing?
Cjmartz2k
Car: Hunting for a '89 GTR now
That's exactly what happened to me. I think you are suffering from Tomuchhorsepower-itis. It's a terrible and debilitating disease
I think my new combination of bigger turbo and MT drag radials did it in. I put in another one and haven't had any problems, yet...................
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
i told you that 2.3 gear was entirely too long for the amount of hp your pushing....sounds like its time for your to switch to the beefier R230 dif and new gear set...
eh?
Is that a stock or aftermarket diff?
Shocker
Car: 89 240sxHB rb26/30
post some pics?
lilskyline240
Car: 90 240sx w/ rb30det
i feel ur pain. one day it seemed like my clutch was slipping at high rpms which didnt make any sense to me cuz it only has like 3000 miles on it but i was also hearin like some grindin noises in the rear end. So i thought maybe me CV joints were takin a ****. Poped the axles out and decided to drop the diff to change the fluid and found every gear on the pinion rounded off on my r200... good thing i had spare in the loft
waitin on that to happen again... stupid Rb's and too much torque
eh?
lilskyline240 wrote:i feel ur pain. one day it seemed like my clutch was slipping at high rpms which didnt make any sense to me cuz it only has like 3000 miles on it but i was also hearin like some grindin noises in the rear end. So i thought maybe me CV joints were takin a ****. Poped the axles out and decided to drop the diff to change the fluid and found every gear on the pinion rounded off on my r200... good thing i had spare in the loft
Stock diff?
lilskyline240
it was a VLSD from a j30
eh?
Did you install the diff itself or the whole pumpkin?
DriftingisLame
Car: '91 240sx coupe, rb20det
I priced out a ring and pinion set here at my dealership. They offer 4.36 and 4.63 ring and pinion sets. Its a "Nissan Motorsports" ring and pinion, not sure if they're hardened or at all stronger than stock ones. My cost was $375 if I remember correctly.
Would you like me to do some more research on them for you?
SullivanRacing06
i priced out a ring n pinion set for my r200 and it was 600 bucks from my local nissan dealership,
so im gonna run the crappy stock 240 ratio in there for now, ugg, id like for someone to find me another 2.90 ratio gear set! ne one know were to find this ratio?
Shocker
SullivanRacing06 wrote: i priced out a ring n pinion set for my r200 and it was 600 bucks from my local nissan dealership,
Are you running a 2 or 3 speed trans here? I don't get why you want that rear end, that is WAY too high for street driving.
lilskyline240
eh? wrote:Did you install the diff itself or the whole pumpkin?
whole pumpkin
SullivanRacing06
2 reasons, the first is i enjoy driving down the intersate at 90 mph at 2300rpm
2 i LOVE top end, ie. 190+ if u deel me
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
+1
SullivanRacing06
gmac708 wrote:
+1
my car dosent lack the @ss to move the car with that ratio, i like runnign from a roll, not diggs.
thanks for the \
glad to see someone else thinks the same way as me
Nealoc187
Car: 95 Maxima
SullivanRacing06 wrote:i just took apart my rear end that came apart on me on the dyno and come to see metal shavigns every where, the pinion is smoother then a strippers a$$, and the ring gear has more teeth missing then are intact
Do you mind if I ask you what sort of power and torque you were making when this happened? I'm starting to research for a VH swap into a car that comes with the R200 stock and I'm planning on making 500-600whp and tq when all is said and done. I'm coming from the FWD Nissan world so my knowledge of the capabilities of each specific Nissan rear diff is very limited right now.
Nealoc187
Car: 95 Maxima
sorry for double post
SullivanRacing06
thsi was only at 538 whp and high 4s on tq, dyno graphs in the shop, im a bit hung over still so im stayin home today
Nealoc187
Car: 95 Maxima
Does this seem to be a pretty common failure at this sort of power level? It's looking more and more like I'd be needing to check out the feasibility of an R230 swap...
SullivanRacing06
i was beating the hell out of the car (launches) on a set of MTs but idk if thatd cause it or not, i just installed a q45 gear set and scratched the 3.92 ratio for a 3.54 (finally) so ive got of my top end back.
not to sure about the r230 rear end power levels
WhatsADSM
Car: 1998 240sx
R230 is supposed to be significantly more beefy than the R200. It is definately physically bigger than the 200. IIRC the output shafts are a lot bigger which is typically where R200 guys have issues.
