float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Mon Jul 14, 2003 11:19 am
is the bolt stripped of the nut? If the nut is stripped you may be screwed. If I remember correctly, the nuts are welded to the insid of the frame and you cna't really do a whole lot with it unless you tap it out and rethread it. If it is just the bolt, then I'd head down to the local junkyard and get one, or maybe you local Roaches hardware.
