Stripped/ stuck subframe support bolts
Traviswurz
Car: 300ZX 1990 2+0
Ok so I searched for over an hour and found 2-3 in helpfully forums on this. When I was removing the subframe support, all the bolts came out with the threads smoothed off. Not sure if from the previous owner or just age but subframe has definitely been dropped before. 3 are out, the threaded nuts are still in there but possibly stripped. One is stuck in and I can’t get out. It goes up and down but can’t get it out... any ideas guys? Having hard time attaching photos off my phone will tomorrow
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Topic moved to correct forum and duplicate post removed.
Posting pictures using your phone can be tricky, but not impossible. Images must be added individually, and cannot be added from a google drive account. Worst case scenario, add the links and I'll fix them if need be. You can drop me a PM for assistance.
How to upload pictures on NICOclub:
Using IMGUR
Using TINYPIC
Traviswurz
Car: 300ZX 1990 2+0
Thank you
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
I used a helicoil kit to repair one of those bolt holes. How much room is there under the head of the last bolt?
You can try to wedge a flat screw driver under the bolt head and pry while unscrewing with a wrench or impact.
